Hullavator for Sue?
  • This topic has 9 replies, 9 voices, and was last updated 5 months ago by Timothy Lim.
  • Creator
  • #27752
    Sue Johnson
    Participant
    I am considering buying a hullavator.  Does anyone have experience or comments that you could pass on?  Thanks!
    Sue J
Viewing 9 replies - 1 through 9 (of 9 total)
  • #28123
    Timothy Lim
    someone is selling a hullavator pro for $700, that’s a good deal.
    Here is the link if you are interested.
    https://www.facebook.com/share/14aEpQfzAcw/?mibextid=wwXIfr
    #27791
    Quirine Schuyff
    Gosh with all of these rave reviews maybe I should switch from my current Yakima Sweet Roll system! I was watching this thread to see everyone’s thoughts. I do like my system but it takes a bit of wrangling.
    #27786
    Timothy Lim
    Hi Sue we bought one last year and it has been a huge difference maker for us in loading and unloading our kayak. It now takes 5-10 minutes to do it and you can tie your bow and stern lines at eye level. The hydraulic makes it super light to lift it up and down. This is a back saver. The install is easy enough I did it myself but the disassembly and reassembly of the cradle part can be a little tricky but after doing a few times it becomes easier. I included a YouTube video here to show the easy step by step install. Also look on Facebook marketplace as sometimes there are gently used ones that can save you some money.
    #27780
    Kapila Jayaweera
    Great piece of engineering. I had almost 8 years now and I love it. Specially work well for higher vehicles like SUV, Mini van, Trucks etc. I can load in less than 10 minutes without much effort and get going.
    #27771
    Don Froese
      <li style=”text-align: left;”>Expensive but worth it. We finally bought ours after falling off a ladder loading boats. Wish we had bought them sooner! They made loading much faster, safer, and easier even for one person. You do need roof racks that extend past the side of the car. We take ours off when not using them.
    #27758
    Kelly Robertson
    Hi Sue, I have had a hullavator for a few years and love it.  I mostly leave them on throughout the paddling season.  I do need to avoid underground parking as my car is often over height, depending on the garage.  I am able to install and uninstall the  hullavators by myself, but it is definitely awkward and much easier with two people.  If you purchase from Rack Stop in N Van, they will install or remove your racks seasonally as needed for no charge.  I’ve had really good service from them.  I can meet up with you if you want a demo to see if it works for you.
    #27757
    Kylie Williams
    Hi Sue. I bought a hullavator recently from Rack Attack and it’s great. I can load and unload solo on a large SUV. Like Caity, my kayak isn’t super-light and I often kayak solo, so it makes a big difference. Also, the Rack Attack person who installed it gave me a tutorial on taking the hinged portion on and off – the pin problem mentioned above – and it’s tricky but doable. I recommend.
    #27754
    Clark Perry-Bater
    Hi Sue,
    My partner has a Hullavator on her car (a large SUV). She leaves the bars for the rack on the car year-round, but removes the hinged portion (that actually holds the kayak) when not carrying her kayak. We find it cumbersome/awkward to line up the holes in the rack and insert the pin that holds it all together before loading a boat. It’s almost a 2-person operation, although I’ve done it by myself once. I guess it depends on the height of the roof. A lower roof would make it easier.
    Once the rack is all set up, it’s a piece of cake to lift the boat up onto the rack (you have to manoeuvre both front and back lifters together).
    Hope that helps.
    Clark
    #27753
    Caity Milton
    Hi Sue, I bought the Thule Hullavator about 3 years ago and it was the best purchase ever! I’m short (5ft), single (which means a lot of solo paddling), and my kayak is heavy (55 lbs/25kg). It has allowed me to get out on the water more often while keeping me and my car safer from wonky fixed cradle manuvering 🙂 Cheers!
  • You must be logged in to reply to this topic.
